주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
Cannot Find Appropriate SSD Mounting Bracket
Hi. I'm trying to replace my hard drive with an SSD. The disassembly went great, but I got stuck when my mounting bracket wasn't long enough to use the iMac mounting system (it didn't have all three holes on each side). So I bought another one, and it didn't have threaded holes for the iMac mounting system. Then I bought a third one, and it works perfectly with the mounting system EXCEPT that there isn't enough length on the data cable. It just wont reach. The cable is just long enough to fit a regular drive. I don't know what to do. Please help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I'm answering my own question. The data cable goes underneath the logic board and comes around the bottom of the computer, just above the RAM modules. There was a tiny bit of slack in the cable, so I gently loosened it and pulled up the slack. Perfect fit. I hope this helps someone else.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
bjelliott 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 95
