주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Why doesn't my iPhone screen work?
i recently broke my iPhone 5s screen. I went to get it repaired by getting a new screen, when i got it repaired the screen began to glitch out and press random apps when i click elsewhere. I later placed a plastic screen protector on the screen and it begins to work for some reason and i dont know why, can someone help me?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hey, did you repair this yourself? Most likey your screen is at fault, it might be working correctly just now however I would guess it will start glitching again soon.
This issue is very common in copy LCDs, if you had it replaced by a repair shop then take it back and ask for them to replace the screen again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
It only works when i add the plastic screen protector to the top of the screen, and i got it repaired in a repair shop
I'd say pop back to them, its definitely a faulty screen. Most decent repair shops will swap it around for you as we're all aware of how poor the parts can be.
댓글 달기
This sounds like bad parts, but it could be a board level defect. Go back to the shop and see if a new screen has the same problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
juan1930 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 61
