주요 콘텐츠로 건너뛰기
2003년에 출시된 Apple의 휴대용 소비자 컴퓨터 iBook G4는 iBook G3를 대체하였습니다.
What does folder with question mark flashing and finder mean?
ibook g4 12
I own an ibook g4 but when i power it on i get a grey screen with a folder flashing a question mark and the finder face, does anyone know how I can fix this? please help !!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
Please give us the Axxx number located on the back of your Book. The speed would also help, then we can direct you to the correct guide.
댓글 달기
답변 1개
선택된 해법
The flashing question/finder face means the computer can't find an OS to boot... This can be caused by a corrupted install, a bad harddrive, or a few other things... Basically, you have to wipe out everything and re-install... How old is the hard drive in it?
이 답변이 도움이 되었나요?
점수 2
댓글 9개:
You don't have to wipe everything. First start up from your system installation disk and run disk utilities to see if you can repair your drive.
Der... Forgot... I would highly suggest wiping it completely out though, unless you have a ton of photo's and movies/music on it
Skippy - If the Disk Repair fails what other steps can the OP do before wiping everything? Then what to do if the (what kind of wipe?), fails?
Is this a test?? If the disk repair fails, I would try target disk mode to make sure it's not the hard drive. If he goes for a wipe, zero out the data and go with the recomended disk format for which ever OS he decides to use.
+ Not a test, just trying to get you to think and give a more complete answer. I couldn't give you an upvote the way it was. Now I can. Next step is replacing the hard drive.
댓글 4개 더보기
댓글 달기
답변을 추가하세요
Stranga 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 6
전체 시간: 4,028
