주요 콘텐츠로 건너뛰기
I lost lighting of the dashboard.
For a 1999 Toyota Rav4; I checked every single fuse and none shows any defect. What fuse that should be responsible for dashboard lighting?
Any other reason may result in such a defect?
Update (07/10/2017)
You're referring to this fuse box location. Yes I did check and tested that specific fuse and every sing one. All functional.
Note that the pic is for a 1998 model but it has same location. Not necessary same fuses locations though.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Have you checked the INSIDE (left of steering wheel) fuses?
Second from top on far left is labeled "GAUGE". It's a 10 amp.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I know it may seem like a silly question but is the interior light dimmer switch turned up all the way?
댓글 달기
My 07 rav4 ft did the same things kept loosing power i don't know what to do. Any help please
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
penhai 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 26
전체 시간: 1,636
