leak battery power becouse of weak signal
my phone got some water but it is still working only the problem is with the signal is so weak and it cause leak in battery power
좋은 질문 입니까?
좋은 질문 입니까?
I wouldn't pin your battery problems to weak signal strength, you've probably done more damage to the board and battery than you think.
Although, yes, weaker signals use more battery than stronger ones due to packet lose, I think yourbattery is damaged.
해당 답변은 도움이 되었습니까?
if I changed the battery then what about the signal ? I feel the main problem is the signal
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 167
