주요 콘텐츠로 건너뛰기
This computer was released by Asus in 2014.
How do I reinstall the system?
I want to reboot my computer, it's slow and the storage is full, even though I don't have much stuff on there. How do I reboot it? I've done it once before, but it was long ago, so I can't remember. The computer is a bit over a year old.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 6개:
What OS version do you have installed?
Did you empty your recycling box?
Hi @@feliciaspyan using windows 10 ? If so there is should be option by the OEM inside to reset your pc.
Try This
https://www.laptopmag.com/articles/reset...
How do I reset it without logging in
댓글 1개 더보기
댓글 달기
답변 3개
As indicated by Augustine, use the link to laptopmag.com.
MAKE SURE YOU HAVE ANY FILES YOU WANT TO KEEP/SAVE COPIED TO A SAFE LOCATION (thumb drive, external hard drive, DVD ROM, etc).
  1. Click Start
  2. Type in "Settings" and click "Settings"
  3. Click "Update and Recovery"
  4. Select "Recovery" from the left-side menu
  5. Under "Reset this PC" click "Get Started"
  6. Make sure your files are backed up, select "Remove Everything"
  7. Click the "Just remove my files" option - This should be sufficient for your needs
  8. Click "Next"
  9. Click "Reset"
  10. Click "Continue"
I believe from this point, you should be back to square one and the initial Windows 10 setup wizard will walk you through the rest of the setup.
If you get stuck, don't be afraid to ask more questions.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
  1. turn power On
  2. press F9 many times. You will have recovery mode.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Je vs conseil de faire une nouvelle installation c'est plus sécurisé
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Felicia Birgersson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 8,255
