주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
What did it break by charging MacBook Pro with a repaired MegaSafe?
History: my macbook pro did not charge but was working perfectly when connected to my old original megasafe. I bought a second megasafe power adapter (with the correct characteristics) from a company which repairs and resells them. After charging my mackbook for ten minutes with it, I realised that the laptop was extremely hot, like burning, I think the charger port looked also burned. I immediately disconnected the adaptor but the laptop did not turn on anymore. Also tried to charge it in the apple store does not work.
Question: what did it burn? How do I find out what is broken to be able to replace it!
Please help me!! It´s a pity to throw it away.
Thanks a lot in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Can you please confirm if by 'magsafe connector' you are referring to the internal magsafe board (also known as the I/O board, or DC-in), or are you referring to the external power supply?
I´m referring to the external power supplier
댓글 달기
답변 1개
선택된 답변
Sounds like you got a bad MagSafe charger.
There are quite a few clones out there which can damage your system! I'm suspecting the one you bought was one of these. Here's more on why you shouldn't buy these: Counterfeit Macbook charger teardown: convincing outside but dangerous inside and take a look at this: Lacking safety features, cheap MacBook chargers create big sparks
Here's a good Apple T/N on checking for a damaged unit and to check your computers MagSafe port: Apple Portables: Troubleshooting MagSafe adapters
Sadly, it sounds like your system was also damaged by the bad adapter. You'll need buy a REAL MagSafe adapter to see if your system was damaged. You might also need to replace the MagSafe port if it got damaged: MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement
If your system was damaged by the cloned adapter you'll need to sue the company that sold you the bad adapter to get damages to get your now damaged computer fixed. Now the hard part depending on where you live you might not be able to sue or the cost to sue will be more than getting your system fixed on your own.
Here's the IFIXIT guide to replace your logic board: MacBook Pro 15" Unibody Mid 2010 Logic Board Replacement and the needed part:
MacBook Pro 15" Unibody (Mid 2010) 2.4 GHz Logic Board 이미지
상품
$159.99
MacBook Pro 15" Unibody (Mid 2010) 2.53 GHz Logic Board 이미지
상품
$189.99
MacBook Pro 15" Unibody Mid 2010 Logic Board 이미지
안내서
난이도:
어려움
30 minutes
MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board 이미지
안내서
난이도:
운영
30 minutes - 2 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Giada Carta 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 235
