주요 콘텐츠로 건너뛰기
Comprehensive set of repair and troubleshooting guides for Nintendo game consoles played on the TV since 1977.
911 질문 전체 보기
Do I replace my power adapter?
Hello, I currently have a Nintendo Mattel version and a NES version that I'm trying to fix up. They haven't been used in years so I'm not sure what is and isnt broken.
I have brought new audio and visual cables to connect them to the TV, I have also brought new fuses for the power plug and they still don't turn on.
I have read a couple of threads here and I don't mind replacing motherboards and what not, but I was just wondering whether it would be a better idea starting with the plug. Complete novice here so I'm sorry if I sound daft.
Is it worth trying to repair the power adapter/plug or should I get a new one? Or should I just jump straight into the deep end and replace motherboards and pin boards and what not? Any help/suggestions would be super useful.
Thanks in advance :)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I would start with the power supply first I would have it tested. Then if that Passes then I would check into the inside pieces of the console itself to see if there is a fuse and if that fuse is blown. My nes 001 does not have a fuse inside.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Lizzie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 40
