주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6은 Galaxy 라인의 다음 주력 제품입니다. 곡선형 스크린 버전은 Galaxy S6 Edge로 알려져 있습니다.
487 질문 전체 보기
Why is my phone not turning on?
This morning, my phone's power button and home button were not responding. I shut the phone down, which resolved the issue. Then the phone started turning off by itself. I would power up the phone to only have it shut off 2 minutes later. Then a static noise starting coming out of the speaker while it was on. It's now not turning on at all. The battery was at about 45% when this started happening. I've tried to hold the power button and volume down button...the Galaxy logo comes up and then shuts off again. And that only happens about half the time. The other half nothing comes up at all. I tried plugging it in, hoping a charge might help, but it has not. The phone is no longer plugged in but the red light is still on. Any insight would be appreciated!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
And if you want to reflash firmware on the phone without using wiping data follow these steps:
http://updato.com/how-to/how-to-install-...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hello danielle ,
it seems some issue occur of your firmware,
1) download smart switch
2) select emergency recovery & initialization where located at right side
3) put the phone to download mode by pressing and holding (simultaneously) the Power, Volume Down and Home buttons
4) select continue option
5) follow the instruction given by smart switch
6) Wait while process completed
7) you almost completed!!!
Note : you have your own risk to do above steps!!! around 3GB-4GB of internet data will be required to download firmware.
Hope this solution helps you to fix your phone.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
danielle 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 1,056
