주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 NEO (SM-G903F)는 Full HD 해상도 5.1인치 Super AMOLED 화면을 장착하고 있습니다. 전면 카메라와 후면 카메라는 각각 5 megapixels과 16 megapixels로 작동합니다. 휴대폰 내부에는 64-bit Samsung Exynos 7580 프로세서, 16GB 내장 메모리, 2GB RAM 및 2,800mAh 배터리가 장착되어 있습니다. 치수는 142 x 72.5 x 8.1mm, 무게는 145그램 입니다. 최초 S5와 비교하여 Galaxy S5 Neo는 전면 카메라, FM 라디오 및 더 빠른 LTE (Cat6)와 같은 더 나은 기능을 제공합니다.
Display discoloration after 2 months usage
I fitted a new Samsung LCD two months ago now the customer has brought it back with heavy discoloration to the lcd.
I used an original Samsung LCD service pack, so its not a cheap Chinese copy.
To me it looks as if it's has some sort of pressure on it but the customer claims it hasn't.
I give a 3 month warranty with all my repairs and if it was something caused by my work then I'd swap the screen under the warranty without hesitation.
See what you think from the picture
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I had the same problem some days ago. The black/violet spots will probably widen until the display turns completely black. I was forced to change it, and it's considered to be out of warranty (at least by Samsung). Maybe it was not your fault. My phone broke even though it did not bother or anything else that could had damage it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Eddie Roberts 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 203
