Why is my MacBook constantly crashing?
I have a MacBook Pro 2.2 GHz Intel Core i7 (15 inch late 2011) (A1286) that always crashes whilst on battery power. When using the MagSafe charger, I can use it as normal.
The crashes have no errors on and the furthest I have gotten to using the MacBook on battery, is the desktop. The crashes are like a complete power disconnection (think unplugging a TV from the socket). And when I power the MacBook back on with the charger, the clock have been reset. If I disconnect the charger whilst the MacBook is switched on, the crash happens within seconds.
I have ordered a replacement battery so will test that out however my current battery charges properly and the condition is normal (see below).
I opened the MacBook and the battery looks fine and is connected properly. I ran the Apple hardware test and it returned a ram error. The MacBook was upgraded to 16gb but I don't think this would be the cause. I did remove the ram modules one by one and crashes still happened.
Factory wiped the MacBook to no avail also.
Whilst researching the issue, I believe I require a MagSafe 85W L shape charger but I currently have a MagSafe 60W L shape charger. Could you this be the issue ? (I ordered the battery before realising this )
Any help will be appreciated.
- Charge information:
- Charge Remaining: 5979
- Fully Charged: Yes
- Charging: No
- Full Charge Capacity: 6189
- Health Information:
- Cycle Count: 643
- Condition: Normal
- Battery Installed: Yes
- Amperage (mA): 0
- Voltage (mV): 12326
좋은 질문 입니까?
