주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Can't get rear camera back in
I ordered the camera off ebay. It doesn't seem to snap back into place. I tried reinstalling the old camera and it seems to work. The new camera is just a little off..
Are all the cameras on ebay pretty much the same (just different sellers)? I tried to pick a seller that sold a lot of them.
I don't think I'm doing anything on my part. I could try holding it in place and screwing it down with the plate, but I don't want to force it in there.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
eBay has a poor reputation among professional repair techs. That is usually where you will find the bottom of the barrel when it comes to parts. Small parts, such as cameras and flexes are even worse. So yes, it is possible that you have a camera that is out of spec and doesn't quite fit.
If you can easily insert your original camera but can't get the replacement one to squeeze in, then order a camera from a reputable supplier, like iFixit. You can follow this guide.
iPhone 6 Rear Camera 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Check the Apple Part # on the ribbon of the camera.
iPhone 6 camera - Apple part # 821-2460-03
iPhone 6 Plus camera - Apple Part # 821-2208-04
iPhone 6S camera - Apple Part # 821-00027-03
Unfortunately, they are all slightly different specs and are not compatible with different models.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jeff Johnson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 9
전체 시간: 115
