Not Charging Because of a piece called B628
When I Repair The Charg Socket I got lost In positive and negative
Then The piece named B628 damage.
I can not change it because I do not have Hot Air,
but is there another solution to make the Power Charge the phone when i connect Him?
좋은 질문 입니까?
점수
0
@gemyelgeneral post some pictures of what you are looking at. Use this guide 기존 질문에 이미지 추가하기 so we can see what you see.
oldturkey03 의
thx
I have uploaded the pictures
Can I take it away?
gEmY 의
How do you know it isnt working anymore? And you can remove it with a soldering iron, ive removed much smaller chips. Just hold it with pliers or tweezers and heat all the pins until it releases
Cameron 의
Well but after removing it the Power does not feel the phone connection to be charged
gEmY 의
The phone probably wont charge anymore as the B628 appears to be a voltage regulator. You can try replacing it but most power banks arent worth repairing. Your best bet is to save the batteries for future projects and save the other parts like the LEDs and USB ports
Cameron 의
댓글 1개 더보기
