My Dell D610 power light comes up and turn back off.
please help me to how do i take care of my laptop that turn on power and turn off back...
좋은 질문입니까?
좋은 질문입니까?
Try removing the battery and then boot up using the ac adapter. See if the keyboard lights flash and if the Dell splash screen appears. If the system turns off immediately, the problem is a bad motherboard. It may be getting a false indication of over heating which will turn the system off to protect the processor. It also could be a power management problem. The over heat detection and power management are built into the motherboard.
If you get a beeping noise, count the beeps and let us know. There are several beep codes that indicate what has failed. This would indicate that the motherboard is good but a component such as memory has failed.
이 답변이 도움이 되었나요?
My own did not come up but anytime I plug i the charger the charger indicator light go off immediately and the system will not come up.. I remove the battery and the charger indicator light still go off immediately I plug the charger to the system... What can I do?
지난 24시간: 1
지난 7일: 1
지난 30일: 14
전체 시간: 550
What happened before this? Have you tried removing the battery and just plugging it in? Are you using an original ac adapter/battery? Has any work been done before it broke? Do you get any beeps or blinking lights? How long does it last before it turns off?
Cameron 의
