Hi there.
Your anwer is quite short.
Of course tlyour statement could be true, but my second thought is:
A Nest Protect is permanently connected to AC power. The 3 lithium cells have a lifespan of at least 5 years.
Moreover, the NEST Protect designers would be quite stupid to sound a firewarning because of a battery-faillure, instead of a warning that says: ‘please replace batteries’.
Go figure: there will be not even ONE test engineer that will let such a stupid design flaw unnoticed!
I had this false alarm problem already in 2 unit (both version 1) only after 2 years of continuous operation.
One of them has been sent back to Nest, and they were so nice to send me a replacement u it (version 2 !!)
The second Nest Protect (verdion 1) failed 1 month ago. To test your ‘replace batteries’ solution, I wwill just put new lithium batteries in that second failed unit, and will for sure report back about the result.
cheers
robbert
댓글 3개
Thanks for the answer.
Checking the batteries was the first thing I did and they all tested good. Right at the top of the scale good, but. I might try putting in a fresh set just in case.
Thanks again.
Robin Wilkinson 의
On a summer night with windows open, small insects may come through the screen. Attracted by the light on the smoke detector, they can set it off. Spray screens and the detector with bug spray. Yes, I learned this the hard way!
Muffet51 의
Please note that many issues are when you do not replace with Energiser L91 batteries. This is the only battery that is recommended for this device.
I had no end of issues when putting new Duracell batteries with reports of low battery etc with 100% good Duracell batteries.
Nest support states that only Energiser L91 is supported.
Andrew Boden 의
