주요 콘텐츠로 건너뛰기
Released in 2006, identified by model number PP20L for e1505
Good source for a Express card 16GB SSD under $30
My laptop has bad overheating issues at the HDD because it's constantly running at Max load. I need a 16 GB expresscard SSD which would be just enough for Ubuntu. Does anyone know of a good source for a SSD under $30? I'll never use my expresscard slot anyway, so this may put it to use. It's a 54/34mm slot. Or an adapter solution. Thank you.
@danj @mayer Anyone?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Anyone? Anyone?
댓글 달기
답변 2개
선택된 해법
@pccheese - George, I doubt you'll find one for so little. How about a micro-drive like this: IBM 1GB Micro-drive
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Alright, thanks. Do you know if I can use my wireless card slot for an SSD?
I doubt it as the needed driver may not load
댓글 달기
I found the reason my HDD was overheating. In the BIOS, there is an HDD option for quiet, performance, and bypass. I suspect the performance mode forces more voltage that this cheaper HDD can't handle, and overheats. I put this settings on bypass and now the HDD stays much cooler.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
George A. 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 423
