주요 콘텐츠로 건너뛰기
27" 화면 2560 x 1440 픽셀 해상도 Thunderbolt 및 MagSafe 케이블 부착물
160 질문 전체 보기
No power on the display. Power board failure?
Trying to fix my dad's monitor. A few nights ago, there was a storm and some lightning struck the power box in his home. It basically fried all the appliances that were plugging into his room at the time, including the Apple Thunderbolt Display A1407.
Luckily, it's a British-style plug, with a fuse built it. I've determined that the fuse in the plug has blown. Replaced the fuse and was able to power up an iMac with that cable. Using that same cable, the display still does not work. I've even plugged my Macbook pro to it with a separate lightning cable. USB ports do now power iphone etc.
100% chance now, that it is something inside the display that is not functioning properly. Is it the power board? How do I go about diagnosing this and where would I be able to find parts to replace the damaged ones?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Check the bottom of your stand for the correct model number. Here's a new power supply for the A1316: http://www.ebay.com/itm/New-250W-Power-S...
UPDATE
Apple 27" Display Thunderbolt A1407 250W Power Supply Board P/N 614-0496
http://www.ebay.com/itm/Genuine-Apple-27...
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
thanks for that. I just checked and it says it's A1407, which means it's the Thunderbolt display, not the LED one. Will have to do some research to see if the part your posted would work.
댓글 달기
귀하의 답변을 추가하세요
Natalie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 2,689
