주요 콘텐츠로 건너뛰기
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
28 질문 전체 보기
when installing new battery the horn sounds. how to stop this?
As soon as the system gets electricity, the horn sounds in an off and on pattern. How can I stop this and install the battery. Alternatively, where is the horn wire to disconnect it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개
I am putting new battery in car . When i connect horn goes off won't
Check if you are connecting the correct battery terminals.
댓글 달기
답변 2개
선택된 답변
Answering my own question: Hook up the battery, then use the remote (car alarm button) to turn off the horn.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
What if you don't have a key fob
댓글 달기
If the beeping persists because your key fob does not work or has a low battery itself, endure the beep until you can start the engine of your vehicle.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Even when I get the car running thorn keeps beeping! Now what?
Start the car, put in reverse, drive and shut off the engine.
댓글 달기
귀하의 답변을 추가하세요
TWB 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 22
30일 전: 89
전체 시간: 26,599
