주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Unable to Download Apps on the App Store
I have tried factory resetting twice. I have used two different accounts and have tried signing in and out.
This Iphone for some reason will not download any apps. All my other Iphones can download apps through these two accounts with the same wifi.
This phone is severely cracked and has an old battery but I don't think they have anything to do with the app store problem.
Everytime I try to download an app it says "Unable to download app" "Try again later"
Any suggestions?
Edit:
Apps icons do appear but the apps do not work when trying to launch them.
After trying DFU restore it says software for this iphone was corrupted during download.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개
I press the download button and it loads for a quick second and doesn’t download
on Mac air, unable to download apps.
댓글 달기
답변 7개
가장 유용한 답변
If you are restoring from back up every time you reset, you may be restoring from a corrupt backup.
Try just Settings --> General --> Reset --> Reset All Settings. Do not choose "erase all contents and settings".
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
I have tried this and was unsuccessful. Thanks for the input though!
Have you tried DFU restore and to not restore from an iTunes backup? Create a new profile after a DFU restore.
I just tried this and it says the software for this iphone was corrupted during download. This is not using a backup.
Ok, download the firmware separately from a direct link at http://www.iclarified.com/750/where-to-d...
Then put the phone in DFU mode. It will give you a message saying it needs to be restored. Instead of letting the iTunes download the firmware again, on a Mac OPtion+ Click the Restore button or on PC SHIFT+Click the PC and select the firmware you just downloaded from the link above. If this still occurs, you may have other issues. Check your computer's hard drive for errors.
댓글 달기
To turn back on, press and hold the on/off button until the Apple logo appears. Settings > iTunes & App Store > Your Apple ID > Sign Out. Restart your device, then Settings>iTunes & App Store>Sign in and then try again. Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
This didn't work for me but thanks anyways!
did you try recover mood ? please do and restore ios then if any eror please inform me
It says the software was corrupted during download
mybe your internet speed was no good try to send nearby technician or appel store ok :)
What happens with me is when I “get” a free app/game it says installed but then it takes me to my account and after I hit continue it tells me to sign into my account for verification and after I sign in it tells me that my “payment” was declined even though it’s a free game.
댓글 달기
same problem ,
just change your connection , turn off wifi use cellular data. works for me i dont know why .
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Even I encounter so many issues with the Apple App Store which is why I prefer more using of third party app stores like Appvalley, Tutuapp and Tweakbox - these app stores are completely free and never disappointed me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
bruh even tweakbox does not work for me
댓글 달기
Wow, Really great I appreciating your knowledge kindly check it out
wifikill for pc
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have faced the same problem and then I found the solution. I have downloaded third party app store called Tutuapp ios and it is working like a charm. Give a try to it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is a nice blog to watch out for and we provided information on how to invest 500 dollars make sure you can check it out and keep on visiting our blog.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Diego A 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 61,759
