주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
My beatsX wont charge(turn on) + wont reset
Hello,
My BeatsX won't charge just flashing white and red when I connect it to the charger + i tried to reset it but the same proplem it doesn't work .. when I click the power potton it start flashing white 3 times then stop..
PLEASE HELP
Thankyou.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
가장 유용한 답변
See if it happens on all chargers. Try Turning the charger over and replug in. Flashing white/red could mean a charging issue. Can’t find anything on web to confirm. When it flashes 3 times is on or connected? You don’t say.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I had the same problem. I sent it back to apple for a replacement. However, before i did that, i tested to wiggle the cord where it connect to the battery, at an certain angle, the headphone works fine, i suspect that there's something wrong with the internal connection.
댓글 달기
read this
https://www.mactip.net/fix-powerbeats-3-...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Same issue here. I allowed the headset to completely drain, from that point it appears to no longer charge or be able to be reset.
when plugged into a power source, the headset flashes red/white/red constantly. Take it off a power source and it dies. I have tried multiple charging cables that I know work and plugged them (with the Beats x plugged in the other end) into a variety of charging sources (1.v/2v/3v plugs).
I can only surmise the things are dead. On how infrequent I used them in the past 18 months, I would say it would be cheaper to buy some £19.95 Chinese specials than these £129.99 American (made in China) junk!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
xzeinahx .aa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 18
지난 30일: 47
전체 시간: 14,604
