Best Manufactur Adhesive to use?
I'm about to work on my beats and I was wondering what adhesive I should use, that will be watertight and removable when I heat it.
좋은 질문 입니까?
좋은 질문 입니까?
Any silicon based glue will be waterproof and they will not require heat to remove . Any[ https://www.google.ca/search?q=rtv+seala...:| rtv sealant similar] to these. You can also try Goop. Its a very durable sealant that's waterproof. Hope this helps
해당 답변은 도움이 되었습니까?
Does it expand? Would you recommend it when working on this device?
the rtv will be water resistant and does not expand . it will pull apart with some help when you need to take it apart . The goop is a more permanent fix you may not be able to get it apart again . Both are waterproof . The rtv glue is cleanable by simply letting it dry and then peeling the excess off . The goop not so much . If your looking for a more permanent fix use JB weld its waterproof but it is not going to come apart ever again .
24 시간 전: 1
7일 전: 6
30일 전: 28
전체 시간: 5,630
