주요 콘텐츠로 건너뛰기
The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
69 질문 전체 보기
Tablet stuck in no command mode,will not reboot
Tablet says failed to mount external SD no such device. I have tried recovery system update,wipe cache partition,wipe data/factory reset,apply update from cache,update rkimage,update from external storage and apply update CV from adb, nothing works,screen is stuck on no command. All I did was turn the tablet on
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Check the USB port that you connect to your computer with. Look for bent pins or something lodged in the port . If there is something in the port use a toothpick or plastic pic to remove don't use anything metal . If this brings no joy , is there a card reader or a sd card in the machine , if so take out any card that may be in the tablet . If there is no card in check the slots for debris and clean them . If you get no joy from this remove the battery . Open the case and disconnect the battery . If the battery is soldered to the board then remove the soldered ground only for a few minutes then resolder . Hope this helps
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
same problem tied everthing
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
tabletdummy_ 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 2,787
