주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
What is wrong with my battery?
My battery randomly drains from time to time (like 1% every 30 seconds) and works perfectly sometimes. A 10 min youtube vid sometimes takes 2% battery while other times takes 10%.
-phone works and functions perfectly
-battery has been calibrated
-charging times are normal ~ 2 hours for full charge
-battery has been recently replaced, perfect wear level on batterylife
-not any apps or anything (checked THOROUGHLY)
-low power mode doesnt change anything
-drains 10% to 30% overnight (~8 hours) no use, no notifications popping up
-turned phone off, waited a few minutes, then plugged charger. It turned on. (if this means anything)
Is this because of a bad u2 ic chip?
Or a bad replacement battery?
Or anything else?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Are you synced with a Mac or PC when you hook up? Diagnostic tools are different.
What do u mean?
댓글 달기
답변 3개
선택된 답변
It sounds like you are on the right track in your diagnosing...but to be sure, check battery replacement is good. Measure the charging circuit to very it is indeed putting out proper voltage to charge. It could be battery, Charging port or the charging IC (s), U2 (Tristar) or Tigress.
Update (08/09/2017)
I'm sorry, I meant you could measure the voltage using a multimeter where the battery plugs in.
Here is a youtube video link that may help.
https://youtu.be/6nrw-Q8-NI8
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Ok thank you! Im confused, what do you mean by the charging circuit?
댓글 달기
가장 유용한 답변
I would recommend trying a new battery, if you continue to have problems then it's probably the u2 ic chip or a software issue rather than hardware. It's fairly common for batteries to be defective occasionally.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Sorry, I tried ading a link but it was removed as spam, so I'll try to ad it here to test charging circuit I answered earlier
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Eric Lieu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 387
