주요 콘텐츠로 건너뛰기
모델명 A1707. 2017년 6월 출시, 이 MacBook Pro는 Kaby Lake 프로세서 최대 2.8 GHz 쿼드코어 Intel Core i7 프로세서와 Turbo Boost 최대 3.8 GHz를 사용합니다.
327 질문 전체 보기
Broken keyboard butterfly clip
I have the macbook pro with the new butterfly 2 keyboard, and trying to clean the "S" key i broke the butterfly hinge. I bought a new piece online but i don´t know if it is possible at all to replace since the plastic dome seems to be glued to the chasis.
What would be the best way to replace it without disassembling the whole laptop?
Can i pop off the dome by brute force and "glue" the new one?
Does apple cover this under warranty?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 달기
답변 13개
선택된 답변
Here's am key replacement guide for your model:
https://www.replacementlaptopkeys.com/la...
Would you mind giving us your source for the key? They have been hard to locate.
Apple A1707 Keyboard Keys Replacement
These Apple A1707 keyboard key replacements features the new designed keyboard with TouchBar,
these keyboard key replacements has the second generation of the "butterfly" hinge clip, meaning you will get a smooth and precise key stroke, these laptop keys are 100% Apple OEM so you are sure to get perfect fit and finish, and fully compatible with the 13" and 15" models.
Please take a look at the difference between the Butterfly 1st Gen vs 2nd Gen, there are major
changes, and the fitment is different, we are selling 100% OEM 2nd Gen butterfly
keyboard keys with the rubber cup included, while others are selling you the 1st Gen.
the 2nd gen butterfly key cap is taller 2nd gen butterfly hinge clip has longer pegs
2nd gen key cap is slightly taller 2nd gen key cap kit will come with hinge clip.
Go down on this page past the video to see the images:
https://www.replacementlaptopkeys.com/ap...
UPDATE 9/2/17
How about it Jon Ridley
@thebookyard Would you fix this for your customers?
UPDATE 9/6/18
Jon, has your company done a replacement guide yet? @thebookyard
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
I got it from there but sadly there is no guide for the model I have.
did you find any good guide @lglossman?
@lglossman Hi since your chosen solution actually doesn't show the keyboard your question asked. Do you think you could be a pal and choose the correct answer which @yvan27 provided. Not saying your chosen answer isn't good it just completely missed answering your question and led me on the wrong path. No offense to Mr. Mayer his technical knowledge is bar none but I wanted to see how to remove them just like your question.
댓글 달기
가장 유용한 답변
This video shows how to replace the butterfly mechanism without removing the rubber cup component:
https://www.youtube.com/watch?v=FF9wTVWZ...
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
Great. That worked like charm. Thank you.
Where did you get the butterfly clip? I need this too PLEASE!!!
I wonder why your's is not the chosen answer? This is exactly what the original question asked. Bravo!
댓글 달기
It's doable. The black area at the top of the cup is just paper-ish, and peels off.
Using my precision screwdriver set, I grabbed the thinnest flat head and started by peeling back the black part. That exposes a small notch at the top of the cup piece, there's also one at the bottom.
You can start by gently prying upwards at those 2 spots. Once I thought I had loosened it enough I started prying from underneath the butterfly and the cup at the corners. Basically just slowly prying and jiggering the plastic nubs out of the board. There's also small layer of adhesive on the cup but mine came off and I wasn't able to reuse it, try to salvage it if you can.
When putting the new one on, the butterfly goes down on the board first. Then the cup fits in the middle through the butterfly and secures to the board through those 4 nubs.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
as my photo shows, the numbs of the cup are fixed on the board, so you can't fixt he cup without a drop of a glue, I guess
Any idea what kind of adhesive was used? As einstein mentioned, it doesn't look like the switch will stay put without it (at least on the left shift key that I'm replacing)
댓글 달기
this shows how the whole key is fixed. it may help
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Guys there is a Keyboard replacement program for some of these machines. Depends on your model. Look here and get it done FREE! https://www.apple.com/support/keyboard-s...
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Just a heads up, while they say you're eligible for a free repair, they might come back and make you pay. I recently went in to an apple store to talk to them about replacing a broken key (it was broken before I popped it out but wanted to check it out to make sure it wasn't just dirt lodged in there) and the worker told me after they ship it out and examine it, they could come back and say the damage was my fault and not theirs and then the repair would cost $475. Just a warning for those who have a broken key like mine and wanted to get it fixed!
do you have any update on whether they made you pay I am in the same boat as you.
I wanted to add to this, I went into the apple store today because I saw their keyboard program covered my laptop model and one of my keys were being faulty. When I got there they told me that the program covers the keyboard four years after your purchase of the laptop, of course, I didn't know this. I did buy apple care for my laptop so I wasn't aware they had this program. They did tell me that the cost of it would be around 400$ but I highly highly recommend seeing if you fall under the battery program because they'll end up replacing the top cover with the keyboard when they fix the battery and it ends up costing half of the actual keyboard replacement (199$ ) much better deal but still on the pricier end. You end up killing two birds with one stone this way.
댓글 달기
Apple changes your keyboard for free now. Check if your model is here and then go to your local apple store: https://www.apple.com/dk/support/keyboar...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Does this apply if we broke some part of button by trying to clean keyboard by ourselves?
It might not. Apple told me that they'd send my laptop out for examination and then call me on their verdict. They told me that because the key is broken (the bottom hinges were broken when I popped it off) they could say its my fault then charge me $475 for repairs. But they can't tell you what their verdict is till you ship it out and they call you
댓글 달기
So... by accident the rubber dome came off. And it just looks like it is just held in place by some sticky residue. A very thin layer of it. I wouldn't just put glue on the board since you have to apply a thin layer only on the dome and none on the switch and contact points.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
having same issue. what kind of glue did you use to put the rubber cup back? thx
댓글 달기
Were you able to solve your problem? I ordered the same key, but can't find any good tutorial on how to install the hinge.
해당 답변은 도움이 되었습니까?
점수 0
댓글 8개:
have you checked @mayer s answer?
yes I did, but there´s no installation guide for the MacBook Pro 15" Touch Bar 2017, hence my question.
No, I wasn't able to fix it. I just got used to have a broken key. My solution in the future will be to never buy apple products again.
Sadly, Apples new butterfly keys are less repairable than the older 2015 models.
guys, you will need the get the rubber cup (its just glued) off and then you will be able to put the hing in its right way. but to do this you need a special glue. otherwise happens this: https://youtu.be/ryRVWBrG8i0?t=2m32s. btw: your 2017 device should be still under apples warranty. so why dont use it?
댓글 3개 더보기
댓글 달기
Can anyone show me or tell how to remove a butterfly clip mechanism ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
hmm... as I understood it is impossible, is that means should I order completely new keyboard ?
It's not impossible, it's quite simple really. Don't be afraid when you hear something click when you attempt to take out pieces, once you take it out ALL pieces should be cleared out, leaving the space empty, the only thing you really need to worry about is the sticky residue in the empty space, that holds everything together DO NOT wipe off this residue
How exactly should one take out the pieces? Just pulling on them doesn't seem to help? Should you apply more force? Won't it break in that case?
댓글 달기
Hello,
I have the same problem with my 15' MBP w/ touchbar: I need to replace both, the hinge and the cup and can't figure out how to do it. Can anybody help? A video on how to do it would be greatly appreciated (I think also by others). Thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
When you glue it back on, make sure to cover all the surface of the cup not just nub parts.
If you only glue the nub part you'll have unreliable key register as well as wobbly key cap.
and mine is already f-ed up so good luck with whoever has the same issue.. :)
also super glue works fine. Just be careful with it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I’m having the same issue. I’m attempting to reinstall it, but do the nubs fit inside the actual holes inside the key space or do they sit on top?
Kinda both, but more on top. They fit well enough to keep the key aligned but it won't fit deep enough to be secured, even if you try to force it.
When you put it back on (rubber cup and plastic clip) make sure to test it.
Press each side of the clip and see if it reacts same way. (pressing either side should make opposite side go down as well.)
If not, gently remove the cup before the glue dries and try again.
댓글 달기
I just replaced the butterfly-mechanism without removing the cup. It seems to be possible by stretching the new mechanism over from one side to the other (just like the video referred to earlier describes). However, the key travel appears to be less than with the original mechanism. I noticed that the original mechanism had 'G018' stated on the upper-left corner, whereas the replacement part has 'G019' on the same spot. I really hope that this worthless mechanism isn't applied in future MBs/MBPs.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi guys,
I have the same issue. My button was stuck, and I tried to clean it. Suddenly the white hinge part broke one small pin, and not I cant attach button back on it. So technically I have broke the button. Does it still allows me to apply for this program of exchanging the butterfly keyboards?
And also, do I need to have officially bill receipt or warranty paper for my Mac book to apply for repair?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You should try to call apple and tell them that the keyboard key is faulty and because of poor quality broke off
댓글 달기
귀하의 답변을 추가하세요
Leandro Glossman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 66
전체 시간: 81,760
