주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
iPhone does not recognize any Sim
Hello,
My iPhone does not recognize any Sim.
What part do I need to replace / fix?
Thanks (
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 3개
선택된 해법
if this is a phone that is new to you- I would check the imei to make sure it is not listed as lost/stolen
clean the sim card
check sim tray for bent/dirty pins.
the paper under sim tray is a great idea..
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Well... Try to put a paper or something thin (~1mm) between the tray and the SIM then put it on the phone.
I can't guarantee you that this will work but why not trying?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Please check if your iPhone have carrier lock or not ? If it is locked with any carrier, that sim only works in your iPhone . If you want to use it with other networks, you need to unlock it from the locked network . For that, you can get unlocking servcie from your service provider or from any of the online vendors like Prounlocking.com to unlock it . Once, you have removed network restriction from your iPhone, you can use it with any other GSM carriers internationally .After that, it won't accept/not recognize any sim card, it may be hardware problem .
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
or erel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 2,620
