iMac not responding to Command R
I have a an older iMac trying to reformat but can not access disk utility on start up using Command R.
Ideas please?
좋은 질문입니까?
Ideas please?
좋은 질문입니까?
Insert your original system installation disk as you boot the machine. Hold down the "C" key while booting. Go to the second page of the system installation when the pull down menu appears. Pull down the Utilities menu to Disk Utility. You can either attempt a repair or do your reformat and then a system installation..
이 답변이 도움이 되었나요?
Mark,
Try Command-Option-R. Start up from OS X Recovery over the Internet.
Good Luck!
이 답변이 도움이 되었나요?
@victory - Victor only the newer 2011 onwards models (a few 2010 as well) have this ability. If he can't get into the recovery partition he likely doesn't have the updated firmware for this either.
지난 24시간: 1
지난 7일: 4
지난 30일: 16
전체 시간: 17,247
댓글 5개
@yvaneck @l3ps do you want to explain why you voted on this comment? Do you even understand what Spam means?
oldturkey03 의
sorry i was frustrated, off course i know what is spam but seems someone on top didn't understand that
all my constructive comment are directly going on spam. tell me what happen
lapo 의
@l3ps not sure what happened but we discussed this on here https://meta.ifixit.com/Answers/View/990...
oldturkey03 의
@weido - Can you tell us your exact model.
Depending on its age you might not have onboard recovery services. In some you needed to upgrade the systems firmware and reinstall the OS.
DanJ 의
Thanks Guys i have it up and running again you all where a great help
Mark Weir 의
