주요 콘텐츠로 건너뛰기
Can I repair the cracked screen myself or that not recommended?
I've been hooking my laptop to a display unit, but I would like to get the screen fixed. Anyway I can do it myself, or is that not recommended?
If not recommended, who would be best, and least expensive, to get it done in North SF Bay Area?
Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Check out this link for a tear down of the display assembly: MacBook Pro Retina Display Teardown
Also check out this youtube video: https://www.youtube.com/watch?v=h5MLalnT...
As for changing the cracked glass... It can be done, and after looking at the teardown and the video you can determine whether this is something you want to do. I couldn't find a supply of only the glass, but if you want to attempt this, then maybe you'll have better luck. You can always buy a used display, and salvage the glass from it.
The other option is to replace the entire display assembly. You can buy that from ifixit: MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly, and use this guide: MacBook Pro 13" Retina Display Late 2012 Display Assembly Replacement
MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly 이미지
상품
$429.99
MacBook Pro 15" Retina Display Mid 2012 이미지
안내서
난이도:
운영
MacBook Pro 13" Retina Display Late 2012 Display Assembly 이미지
안내서
난이도:
운영
20 minutes - 1 hour
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Judy Tipple 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 51
