주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Home Flex Cable Replacement
I was fixing the batter (I have battery issues) when I accidentally bumped my phone off the counter and it tore (completely separated) the home button flex cable. I ordered a new home flex cable, but after doing some research- will I need to
A.) buy a new home button as well?
B.) will I lose my touch id function even if i keep the home button?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
hi Taylor, you must use it with your home button otherwise you will lose touch id function.
goodluck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
If you tore this cable, you are okay with the touch id
But if you tore this cable, then you will need to buy a replacement button and you will lose touch ID but home button function will work
해당 답변은 도움이 되었습니까?
점수 5
댓글 4개:
Great! I tore the flex cable up at the top, like the first image you've shown. I'll just be crossing my fingers until my flex cable gets here :)
You are fine then, just use the original home button:)
Taylor, you accepted the wrong answer ;-)
@mayer at least she got an answer she is happy with ;-)
댓글 달기
귀하의 답변을 추가하세요
Taylor Fuller 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 71
