주요 콘텐츠로 건너뛰기
구글 픽셀은 2016년 10월 20일에 출시된 구글의 첫 번째 플래그십 스마트폰입니다. 5인치 AMOLED 디스플레이 장치에는 32GB 및 128GB 스토리지 옵션이 제공되며 베리 실버, 콰이트 블랙, 리얼 블루의 세 가지 색상으로 제공됩니다.
20 질문 전체 보기
Where is the pixel wifi antenna?
my pixel fell onto ground and since then the wifi becomes very weak. wifi can be found but not connected unless i put the phone on the wifi router. maybe some problems are within the wifi antenna. i tear the pixel down but cannot find the wifi antenna. can anyone show me the position? really need help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 5개
I am also facing same problem. Can you please tell me how did you fix your connectivity issue?
@tosepe  could you fix the problem? I have the exact same issue after i dropped it. It would be very helpful if you share what happened
How was the problem fixed? Was anyone able to solve it?
i have also the same issue with my pixel
My speeds on my pixle 3 XL is 15mb with data and Wi-Fi compare it to my Samsung note 4 and my note 4 is getting more than double of the speed my pixel 3 is supposed to get
댓글 달기
답변 3개
선택된 해법
Hi!
I think what you are looking for is in thisguide, at step 14. Those are the antennae.
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
Thanks for help! do u mean the black signal wire? is it itself the antennae? or the connecting wire between the wifi chip and antennae?
The both the black and white signal wires are antennae connected to the WiFi chip.
Hi there! I have this exact same problem too. Can you please tell me how you got this problem fixed? Thanks
댓글 달기
가장 유용한 답변
if the above didn't work try to press little hard on the left right corner(next to power button where wifi chips sit on the motherboard) this is the most successful solution at least for me because I cannot get a replacement from Google because I am from Cyprus (my device is google pixel xl,
Hope the solution is helpfull for you or anyone who has this problem)
이 답변이 도움이 되었나요?
점수 14
댓글 13개:
mine fell a floor from the balcony, broke the glass (not the screen) and the wifi.
thanks for the advice, works like a charm now. :D
thank you! i dropped my phone this morning and had the same issue. i was preparing to disassemble the phone and try to fix it but this worked like a charm!
You, sir, are a genius! I was looking at how to disassemble the phone because I had the same issue (the phone fell on the floor from 30cm, nothing got broken, but wifi stopped working). Pressing on the corner next to the power button FIXED IT!
Demetris, you saved me a lot of time and money!!! THANK YOU!!!! THANK YOU!!!! THANK YOU!!!!
thankyou v v much.. thank you.. this absolutely works.. thank youu à
댓글 8개 더보기
댓글 달기
Thank you, my device has this problem, and I can use wifi simple.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
taro.yu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 52
전체 시간: 16,852
