주요 콘텐츠로 건너뛰기
A followup to the LG V10 smartphone, similar to the LG G5, released on September 29, 2016. The LG V20 can be distinguished by the model numbers F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996, and VS995. It is available in titan, pink, or silver with 32/64 GB of storage.
51 질문 전체 보기
Date and Time on Sleep Mode
My battery seems to be draining pretty fast. Doing whatever I can to remedy it. My question is, I just bought this V20 Unlocked and when it is in sleep mode, it constantly displays the time and date at the time, it's very dim but you can still see it.
Can this be removed or is this time and date on the sleep mode built into the phone where you can not disable it. Please help.
Thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
You'll want to disable ambient display. Go to settings, display, then switch off ambient display. That should cut it! Also look at battery usage in settings and report your battery usage data.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I went to setting then display and I don't see ambient display
댓글 달기
Step 1: Settings
Step 2: Quick Cover Case
Step 3: Second Screen Settings
Step 4: When Main Screen is Off
Step 5: Toggle the “When Main Screen is Off" from On to Off
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ron Gacek 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 7
전체 시간: 679
