주요 콘텐츠로 건너뛰기
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
100 질문 전체 보기
SM-T800 (WIFI) and SM-T805 (LTE) the same display?
Hi everybody,
I am trying to repair my SM-T800 (WIFI, black) because the whole Display (LCD + Digitizer) is broken.
My plan is to buy a display of a SM-T805 (LTE, white) and put it into the SM-T800 (WIFI).
Now my questions:
Is possible to merge the two models? Where are the differences? Could there be any problems?
Thanks a lot in advance! :-)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi!
You can merge the two models.
The difference between the Wi-Fi and the LTE model is the SIM slot on the motherboard, but that does not affect the display assembly at all, so go ahead with your repair.
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
Thank you very much for your fast and helpful answer!
How difficult is it to change the display of the Tab S 10.5 ? I'm wondering why there is no tutorial for display change :-)
Thanks and cheers!
I don't know why we don't have a tutorial on how to change the display, buy it shouldn't be difficult. All you have to do is to remove basically everything until you are left with the display assembly. You could also upload a guide on how to change it yourself, help others in the future.
Yeah, I'll do that :)
댓글 달기
Bonjour (Hello in French)
Do someone know if I can merge the motherboards of the T805 (the LTE 4G model) and the T800 (the WiFi model) ????
In other words, can someone confirm the sence of Alex Niculescu, saying "the difference between the Wi-Fi and the LTE model is the SIM slot on the motherboard,...
A friend of mine gave me a unserviceable Samsung T800 WiFi model. He wanted to change the USB charger connector but he broke connectors of the motherboard that is broken. I found some T800 and T805 motherboard (the price is nearly the same)
Of course,if this modification is possible, I imagine I will have to modified the plastic backframe to insert the SIM card.
Thanks in advance for your answers
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hello, I face exactly the same situation. i broke the charger connector on the motherboard of my T800, and can get my hands on a T805. Was going to take the motherboard from the T805 to replace the T800 one. Did you end up doing this or get any answers as to if you can?
댓글 달기
귀하의 답변을 추가하세요
cloey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 1,397
