Why is my acre laptop beeping but not switching on?
When I press the on button my laptop looks like it is powering on and the blue light comes on however the white screen comes on and beeps but just switches off again?
좋은 질문입니까?
좋은 질문입니까?
I thought at first you meant a beep code, reading the question again I believe the white screen is the video card not on, I would say you have a dead or shorted bad battery or your hard drive is gone. The beep is from the bios going past checks and on to start the operating system on the hard drive which is dead, or you have just enough power to start but drops off when trying to use more current.
So, question. Is it plugged in to your power supply? Remove the battery and try again. a shorted battery can steal the power. Next try a start again and listen to hear the fan going plus the hard drive.. Now if you actually hear more than one beep or a continuous beep or more than one beep then post your answer so we can move on to help. If you get only one beep , no cooling fan or other noises I think your hard drive is gone, or wiped.
Post your findings so we all can work our brains more on this.
I have had this but no white screen, this is confusing...
Alton
이 답변이 도움이 되었나요?
The white screen is usually indicative of a failed hard drive not a video issue but there are multiple issues on this one.
Fan works and I'm getting 3 beeps with a black screen
How do i solve problem
On this webpage you will find a list of beep codes for most motherboard BIOS.
Find the provider of your BIOS and check the diagnostics for each different beeping signal. From that point on, if you report back, someone will be able to help further.
이 답변이 도움이 되었나요?
As always, to get a better response you have to let us know the model number, what operating system. We await your response
My problem is my computer cuts on but black screen of death. I did almost everything I can do to get it back working again. Sadly this computer doesn't have ram I can take out and replace it. I turn off my laptop, unplug it, unscrew behind my laptop, disconnect the battery, wait about 2 hours. Reconnect the battery, screw everything back to the way it was, flip it over, connect my charger plug in, press the power button on, still nothing but the blue light that indicate it's on. I ran out of options on this one. Do you have any suggestions on how to make it work. Anything is helpful.
이 답변이 도움이 되었나요?
My Acer aspire 5733z turns on it says please wait in bottom left of screen then keeps beeping then turns of and starts up again doing same thing over and over.
1 minute ago by T Fra
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 10,513
댓글 4개
Is the "Beep" a single beep or a beep code? What do you mean by white screen? Is the computer going through post/ can it get to BIOS? By blue light do you mean the power indication light or something else?
Mr Eclectricc 의
How many times is it beeping? Is it long beeps and/or short beeps?
Tim Rauls 의
Beeps usually mean a bad memory chip...
Count the beeps. Short beeps? A long beep?
Qyron 의
T Fra 의
