주요 콘텐츠로 건너뛰기
PS4 컨트롤러 모델 CUH-ZCT1. 소니 컴퓨터 엔터테인먼트에서 2013년 11월에 출시한 이 6축 3.7V 리튬 이온 배터리 컨트롤러 수리는 복잡하지 않습니다. (참고: 해체 안내서는 이 모델용이 아닙니다.)
Why is my r2 button not working
My r2 button wont work right I have to press it really hard in Battle feild wont work in gta5 .
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 2개
Chk the rubber on L buttons if ok!.
May need some control setting on call of duty. Shooting button response fast/slow
Hope this answer fix your prob.
I recently brought this PS4 controller on Amazon and now it’s not working on R2.
댓글 달기
답변 4개
선택된 해법
Dont know of this helps or not but…. If your controllers get dropped regularly, like mine do…..take it apart, carefully clean the contacts of the conductive film and it's respective contacts on the circuit board. I use 90%+ isopropyl alcohol and a few Q-tips. Scrub, but carefully. Then use a clean cloth to buff the film contacts and the board contacts. Make sure everything aligns correctly when you screw the circuit board back down. Screw the circuit board back down and connect the battery and try it out. Unless your controller is physically broken, or the rubber pads are torn or crushed, this should fix your problem. Unless it was submerged in fluids, just smashed to !&&*, or a button was physically broken from being to rough….this had fixed every single one I've come across with a “shoulder buttons worked and now they don't “ scenario. It's almost always that film. It moves and that was a design flaw.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Do you have any tips for the R2 activating when you're not pressing the trigger?
You could also switch the triggers to the bumpers (in the accessibility menu)if you dont want to break your controler or if you dont know how to work with the components (like me)
댓글 달기
가장 유용한 답변
Could be a number of issues: the plunger on the inside of the button could be cracked, the button switch could be loose, or there could be dirt or damage to the button switch. Gonna have to open it up and have a look.
DualShock 4 (CUH-ZCT1U) Buttons Replacement
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Here’s a simple solution to fix buttons that don’t seem to be working. It does requiring taking the controller apart.
https://www.youtube.com/watch?v=Lx3La8a1...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Dude I logged in just to say thanks lol this link helped me big time. Just managed to fix my controller
댓글 달기
How do i fix my r2 button to shoot without pulling it apart
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Blow air into it with ur mouth worked for me
Did not worked for me lol ear me out if there is another solution to repair it whitout pulling it apart
Coby Roberds that actually worked, thank you
댓글 달기
답변을 추가하세요
Lane Bauer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 21
지난 7일: 153
지난 30일: 778
전체 시간: 160,421
