주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2265 질문 전체 보기
The proximity sensor is not working after I replaced the screen.
My phone doesn't black out when i make a phone call like the exact same phone does. I replaced the proximity sensor and front camera cable and still nothing. What could it be?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
@kennyck3
It could the following
Alignment the sensor has to be aligned correctly
The flex itself a lot of replacement flexes I've found are just rubbish they work for camera and speaker not the sensor
It could be the screen could be too dark could be too light
It could also be the connector the flex goes to, damaged from prying
Try a known good flex and align it like the original, try the original screen with the flex u think is good, always rule out bad parts first
댓글 달기
답변 1개
You Change any others lcd? if not try any others lcd plz try.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
kenny 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 167
