주요 콘텐츠로 건너뛰기
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 질문 전체 보기
Replaced cracked screen, now new screen comes on but touch not working
I have just replaced a cracked screen on the iPad mini 2. It turns on but does not react to any touch commands. Have taken back off, reset plug and put back on. Same thing happening. Please advise....thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
This could be just a bad digitizer. If you purchased this unit off ebay or amazon, it is most likely a cheap product. If you have followed all the steps on ifixit on how to replace your digitizer and you still have no touch, it is most likely a bad digitizer. Did you have touch capability with the original broken glass?
Buying quality parts are worth the price.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Before assuming it is a bad digitizer, try reattaching the flex cables. Make sure that they are COMPLETELY attached. I've changed a few iPads and the touch wouldn't work because the flex cable wasn't completely attached.
I purchased the screen from here (iFixit). We have followed all the steps (several times) including reattaching cables and such. The original broken glass worked fine, just cracked.
@tantonivich The front piece is the digitizer which does all the touch work, all parts can be faulty and all parts can be damaged during installation no matter where they are from, try another digi
댓글 달기
귀하의 답변을 추가하세요
tantonivich 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 72
