Why does my 2000 ford ranger shift hard
whats causing my truck to shift hard it jolts when it shifts
좋은 질문 입니까?
좋은 질문 입니까?
Quite a Few Factors involved -
We'll assume 200,000 miles.
Current care along the way, Trany Fluid Chges - mandated.
Drive train inspection- rear end serviced, all typical service.
Automatic wise, I still shift it manually, to help keep clutch packs from severe up shift demanding hits when there is high mileage.
Instead, take each gear a little higher in speed, backing off on up shift , to let clutch packs get a good grip first, before applying power... it's just a half sec.
Hard hits by itself- tell me clutch packs are about done,
The gap is such, when fluid is applied, it has to force the piston plate further to squeeze the clutch packs, and you might have foot pressing on throttle at the same time - forcing it to hit harder just as it's about to engage.
We'd roll it into Tranny Shop for full testing.
In a rare case, vacuum also controls soft / hard hits, But I'm not sure on this model.
This might be full Mazda Drive train.
해당 답변은 도움이 되었습니까?
I have a 2000 automatic with a 168k on the odometer and it actually runs phenomenal for the high miles but from the 1st to second gear usually around 20 mph it runs about 6k rpms which is clearly too high for the first gear but then after that it runs like a beauty in all other gears I haven’t gotten to it yet but these 4 cylinder rangers have a Mazda like transmission which are known for hard shifting on high miles I’m about to dump all my tranny fluid out run a full bottle of Lucas tranny fix through it and put the tranny fluid back in
Hello Jesse, somehow I missed this post.
Hopefully your truck still lives.
I'd probably would have done the same using the Lucas additive.
Good chance it will re conditioned the seals in clutch packs to get a better shift action.
All the best Captain.,,
Cheers
24 시간 전: 0
7일 전: 7
30일 전: 40
전체 시간: 7,460
When light come on 1 gear hit hard but it does do it till 20 mph when it hit hard
Mike McClain Jr 의
2001 ford ranger edge 4.0 2wd automatic. I changed out my radiator,fan blade, and water pump. Took it for a test drive after idling for 20 min checking for leaks and let it reach operating temp. All was fine til I put it in reverse to back out of driveway. I felt a slight jolt. I proceeded to put truck in drive felt it again. Got up to 20 mph and truck would NOT shift. Let off accelerator and it shifted. Got up to 25-30 mph and transmission began to slip. RPM s began to decrease while accelerating. Obviously I quit accelerating and returned home a few blocks away. Checked trans fluid. Its in the xxxxx and doesnt smell burnt. Been a bit since trans filter has been changed. Its been a good truck. 270,000 miles hate to put her to rest. She still had alot of pep til I changed out radiator,fan,water pump. Drive to grocery store and walmart few times a week. Hoping she'd hang around a bit longer. Any thoughts besides shooting her. Yes, I'm talking about my truck Thanks
Kap 의
