이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
Please confirm your exact model. You didn't give us much to go on here. A history, accidents, exactly what it will do, if you've tested the power adapter, how you know it's fully charged, when and if the batteries have ever been changed, if its been worked on, would help us to help you.
Did something happen? Did you drop it, spill something on it or did it randomly stop working? It's usually a ribbon cable that got loose or if the hinge is broken then the ribbon is most likely ripped
mayer 의
I stand by what @mayer said. You need to give us something to work with here.
Alex Niculescu 의
