주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
How do you replace the digitizer only?
I have come across a screen I tried to refurbish and I somehow separated the digitizer from the LCD. I was trying to figure out if anyone knows how to adhere a new digitizer that comes installed on the glass already to the LCD? This is what I was looking at buying. I can't find it on YouTube but I am not sure if it am wording my search correctly. this is what I found for a replacement part.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
I know this won't answer your question exactly, and I'll let someone else give you instructions. If it were an android phone, and due to the high cost of their screen replacements, I would advise it...
However, replacement lcd/digitizer assemblies are so inexpensive now for the iphone 6, I would suggest not going through the headache of what you are attempting to do.
You can get replacement assembly for the 6 as low as $15.
I use to refurbish iphone screens, and the time and risk just doesn't weigh out anymore.
So I can't just throw a piece of OCA between the two huh?
Did you end up trying OCA, or any other method? How did it work?
댓글 달기
답변 1개
가장 유용한 답변
there is adhesive that comes with it which can be pull after heat up hot air. but you will need to look for good adhesive to glue it back. otherwise it will be really ugly. i would advice you find the complete front panel
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
So would OCA be good enough to get the two pieces together?
댓글 달기
답변을 추가하세요
angelscreenrepair 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 12
전체 시간: 3,106
