주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
proximity sensor issue?
Proximity sensor works but it stays constantly on (screen turns off at calling without holding it to ear). I also checked it using code *#0*# everything else, is good proximity sensor displays 1 and screen vibrates and turns green. The ear piece area seems a bit loose. Can this be fixed without opening and replacing the proximity sensor or i need to replace this.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
Yes, check out the teardown.
Proximity sensor lies below the LCD, which is not minor surgery to remove.
Samsung Galaxy Note 4 Teardown
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello, I have the same problem as yours. The proximity sensor is crazy.
During *#0*# test, for the proximity sensor, proximity sensor test displays 1 and screen vibrates constantly and always is green , exactly like you described. I have a samsung S7 Edge.
During calls, the phone screen turns off without holding it to ear! In WhatsApp calls, I can not even hang out because the screen freeze completly!
At first, I thought that it was related to the Roms, I tried a few, and even the Official from Samsung got the same issue.
So with the result from the sensor test, with *#0*#, I am (99%) sure that proximity sensor is guilty, and plan to change it. But how can it have been damaged?? kind of wierd.
How didyou resolved the problem?? did you changed the sensor??
Thx for any feed back, and recommandations.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Max 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 7
전체 시간: 2,393
