주요 콘텐츠로 건너뛰기
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
133 질문 전체 보기
phone speaker volume extremely low even with volume up to maximum
external speaker barely audible with volume control up to max. Can't hear phone calls, media or ringtones or alarms. just started this problem a few days ago. phone is barely a year old if that. Z981 from MetroPCS
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 20
댓글 10개
After increasing all volumes to max and still low hearing then Clean the small slot on the face of the phone at the top. Just besides the selfie camera. First rub with damp cloth and with a dry cloth hard. This is your call speaker. Bottom of the phone is media speaker.
Thank you so much! I thought I needed a new phone!
@longtall Thank you! This really helps a lot !! :D
You're the best. It worked
Bull Hockey. First Reboot Your Phone. Then Adjust Volumes A Few Times Until Sound Previews Are At Full Volume.
댓글 5개 더보기
댓글 달기
답변 4개
선택된 답변
check the speakers are clear they often get dirt or lint in them from your pocket and it kills the volume same can happen to the mic
해당 답변은 도움이 되었습니까?
점수 13
댓글 1개:
How do I do that
댓글 달기
if after all the things you tried then its time to buy some ifix it tools and order a new speaker part and replace old with new and see if it works.
해당 답변은 도움이 되었습니까?
점수 8
댓글 2개:
it's my phone. has no volume at all it's on high as it can go and my phones speaker dos not working
im not buying a new one
댓글 달기
Mobile speaker skeling and speaker power
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
My phone is to quiet
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jeff W 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 14
7일 전: 105
30일 전: 443
전체 시간: 188,384
