주요 콘텐츠로 건너뛰기
The Kenwood Chef A701A is a stand food mixer released by Kenwood.
47 질문 전체 보기
When I insert the wisk or K-part it comes apart after a few seconds
Sorry, my English is not really good.
My Kenwood Chef works and rotates, but when I try to mix butter or dough, it turns itself loose and the middle screw (at the axis) falls in the dough.
It started after kneeding a tough christmascake last year ;-(.
Here is a clip of what happens.
https://youtu.be/bGVAsRTYXCM
Can anyone give me advice how to repair it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Take the central nut off. Try and remove the planet hub by wiggling it with a downwards motion.
Check that the gear (cog) on top of the beater socket is not damaged (sometimes they’re made of plastic and have broken or split). If necessary fit a new gear (available online) and secure with a 5 mm starlock washer/push-on fastener. Whilst its off you could clean off any old dirt/grease using a cloth with some white spirit, and re-lubricate around the teeth on the underside of the gearbox with a smear of grease. Also check that the hole in the middle of the hub is still “D” shaped - these can wear down with age.
Replace the planet hub and refit the nut using a new washer (plastic or fibre) between the planet hub and the nut. An M6 nylon washer should be the right size. Do the nut up with a spanner, but do not overtighten as you don’t want to strip the threads. Note that there may be a small gap between the hub and the nut if the new washer is thicker than the original. This will not affect operation.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
If the "whole in the middle" of the planet hub is no longer "D" shaped, do I need a new planet hub, or is there a fix? Thanks
댓글 달기
귀하의 답변을 추가하세요
Bregje Kaars Sijpesteijn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 31
전체 시간: 613
