주요 콘텐츠로 건너뛰기
일반적으로 통합 스크린을 포함하지 않은 이동하지 않는 컴퓨터입니다.
2134 질문 전체 보기
What software is good for stress testing in constant loop?
hello all,
I have been overclocking my system and trying to find stability . In battlefield 1 it sometimes takes 40 minutes or so before my system crashes due to instability . I have 3d mark advanced and can only run a 10 minute stress test . I want a stress test that I can run for 1 or 2 hrs or custom amount of time which would be much more suitable . Is there a paid/free piece of software for this ?
Thanks.
I didn't find the right solution from the internet.
References:
https://www.computerforum.com/threads/wh...
Marketing Campaign Examples
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
Prime95 is my go-to program for checking stability.
https://en.wikipedia.org/wiki/Prime95
It is very common for people who overclock their CPUs to use Prime95 to check the stability of their resulting system. If the computer cannot run Prime95 for 24 hours is is likely that the current Overclocking selection is not reliable enough and needs to be adjusted.
I have used Prime95 since the Pentium II / K6 days.
Good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
One of the best free tools to stress test the CPU, memory and GPU is actually Intel’s Xtreme Tuning Utility. This utility will allow you to select which component to stress test, for how long, and it simply does its thing. As Intel XTU is designed for overclocking the CPU. The utility will give information about the CPU such as utilization, frequency, temperatures, and whether thermal throttling was detected during the stress testing.
https://downloadcenter.intel.com/downloa...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
One of the best free tools to stress test the CPU, memory and GPU is actually Intel’s Xtreme Tuning Utility. This utility will allow you to select which component to stress test, for how long, and it simply does its thing. As Intel XTU is designed for overclocking the CPU. The utility will give information about the CPU such as utilization, frequency, temperatures, and whether thermal throttling was detected during the stress testing. I want to suggest you that you wil install the antivirus in your pc and secure your devices from virus and kaspersky in very nice antivirus
and you can purchase it at reasonable price.
https://kasperskyantivirusoftware.wordpr...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ryan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 594
