주요 콘텐츠로 건너뛰기
The JBL Charge was released in 2012. It features Bluetooth and 3.5mm audio for a wide range of inputs. A high-capacity 6000mAh battery provides several hours of entertainment and can charge other devices with its built-in USB port. Available in Black, Green, Gray, and Blue.
28 질문 전체 보기
My son's jbl charge got wet, I would like to try to fix it.
It actually fell into a hot tub. I would like to know how I can determine what component are bad. It will not power up or change . I have volt meters, to do any testing I might need to do. Or should I just replace the battery. Any advice that will help will be much appreciated.
Thank you
Dr. Carter
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@kimber1911 for now you do want to stop trying to charge it or to power it up. After all, this is a water damaged device and trying to do any of the aforementioned could be making it worse. Use these guides to disassemble it. Then clean every part with 90%+ isopropyl alcohol which includes cable connectors etc. Then once you cleaned it properly replace the battery and only then can you try to turn it on and perform more fault finding if it should still be needed.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank for your help, I will give it a try.
댓글 달기
귀하의 답변을 추가하세요
Denis Carter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,769
