주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
561 질문 전체 보기
iFixit Battery replacement works until 25% battery life
Replacing the battery was no small task but went well.
I followed the directions of letting the battery discharge, then charge to 100% then discharge and charge to 100% again, then continue with normal use.
However, that normal use will get me to 25% remaining life and then the laptop will shut itself down.
I have reset both the SMC and the NVRAM.
Laptop seems to function fine other than that.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
Have you checked it with a dedicated battery program like Coconut Battery
http://www.coconut-flavour.com/coconutba...
I have not used that specific app (I have been using Battery Monitor and Battery Health from the App Store), but if I must here is a screen shot: https://ibb.co/cq0qG5
As you can see nothing out of the ordinary like I stated. I don't get a warning from the machine with my settings set to 5% to alert me of low battery because the laptop shows it is at 25% still.
Same issue here again. Mine worked for a couple of charges and then it went back to 10%. I asked for an exchange.
Yes, my exchanged battery now goes down to around 3% before powering off. I am good with that.
댓글 달기
답변 2개
선택된 답변
Return the battery, it is faulty if you have tried resetting the SMC and NVRAM.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Finally got through doing tests the team at iFixit wanted me to do. They are sending me a replacement battery to try again.
댓글 달기
OK, I just got a new battery from ifixit and got the same problem but it was turning off at 30%..
I was able to solve it by cycling the battery. Is annoying but it works:
-Fully charge the battery and leave it connected and charged overnight.
-Then use the laptop until it runs out and turns off by itself. Leave it discharged for about 4-5 hours or more.
-To verify if the trick works, pressthe Power button and make sure you see the "Connect to the power" symbol.
-Then fully charge it again.
After cycling my battery capacity dropped a bit, but at least now is accurate. I recommend doing coconut battery monitor.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Glad to hear your issue is sorted out. I did your suggestion a day ago when I found this site: http://www.newertech.com/batteries/power...
The laptop will now get to 9% battery before it kicks off so it is better than my original 25%. But still not acceptable. I am working with the iFixit team now and doing what they suggest.
Do it once again. I had to do it again to get it perfect. Now it turns off at <5%. I might need to do it a third time.
Have done it several times. Still no luck, it actually went back up to 15% and would shut down.
댓글 달기
귀하의 답변을 추가하세요
Ken Charity 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 199
