주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
My wifi sometimes does not work after I move my laptop...
My wifi sometimes does not work after I move my laptop, which leads me to think that it is either a wifi cable or wifi card problem. My bluetooth still works though. I don't know if it has a bad connector or something too. Whenever it cuts out, I turn off my machine and just unhook the wifi cable and put it back, then it works again. What should I do?
Update (09/20/2017)
It is definitely not a router thing. This happens no matter what wifi I am connected to. Key word is movement here. It seems to be more prevalent when I move my laptop.
MacBook Pro 13" 2.5GHz i5 (Mid-2012)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
You’ll need to focus down a bit here on which model you have. Apple has created quite a few different variations of 13” MacBook Pro’s.
How about plugging in your systems Serial number which you can find under ‘About This Mac’ into here EveryMac - Lookup, then paste your systems URL here so we can see it.
댓글 달기
답변 2개
가장 유용한 답변
Are you popping off the bottom cover of your System every time to get it to reconnect? Or, are you altering the Router by unplugging it? If that’s the case can you give us a bit more here on your router (WiFi Access Point).
Update (09/21/2017)
A common problem in this series is the WiFi cable fails. Here’s the IFIXIT guide you’ll need to follow: MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement and this is the part: MacBook Pro 13" Unibody (Early 2011/Late 2011/Mid 2012) Airport/Bluetooth Cable - Apple P/N 922-9780. I would start there.
If that fails to fix things you’ll have a bigger job replacing the WiFi/Bluetooth antenna unit which is in the clutch cover. You’ll need to take the display off to gain access to it.
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Cable 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Sorry and to your earlier question, I am popping off the bottom cover of my System every time to get it to reconnect. As a follow up question, if the problem were the wifi cable, would the bluetooth not work either?
A damaged cable can have odd behaviors! I've seen one or both fail.
댓글 달기
Have you try updating all your updates on the app store? Also do this and follow instructions here this : https://support.apple.com/en-us/HT204063 should help us know if is software related or hardware let me know Rebecca !
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I know 100% that it is a hardware problem because I am popping off the bottom cover of my System every time and unplugging and reconnecting the wifi cable to get it to reconnect.
댓글 달기
귀하의 답변을 추가하세요
Rebecca Fan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 164
