주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
LCD display works, but brightness/backlight is dim
I just purchased a used MacBook Pro (13-inch, mid 2012). NON-retina display. Everything works fine, but the LCD screen seems a bit dimmer than it should. When I turn the screen up to full brightness, it doesn't seem very bright. When brightness settings are turned down low, the screen is nearly black. Everything seems to display okay, and the colors are fine. I calibrate the monitor with a Spyder 4 Elite, and the color rendering is acceptable.
Wondering if replacing the backlight would solve the problem? If so, is it possible to replace the backlight only, or would I replace the whole LCD? If it's the LCD, would I need to replace the entire LCD assembly or just the LCD panel. (I think these LCD panels have integrated backlights, but I'm wondering how to tell if the problem is in the backlight or somewhere else in the computer/display assembly.)
Other relevant tech specs:
Mac OS Sierra 10.12.6
Processor 2.5 GHz Intel Core i5
Memory 4GB
Graphics Intel HD Graphics 4000 1536 MB
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hey Charles,
To me the problem sounds more in the backlight circuit that drives your backlight screen and not the screen itself. (Most of the time this is because you spilled some liquid a while back or something). (most of the time the screen goes completely black).
Get it to a repairshop that does microsoldering on macbooks, it should be a problem they can fix.
if you have any questions, let me know
Kind regards,
Tom
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks. Would this fix require new parts? Any idea of how much something like this would cost?
Hey Charles,
Assuming this is the problem, the cost of the parts is minimal but the labour hours are extensive and needs to be performed by someone with some skills. Think around $200 for the repair.
Kind regards,
Tom
댓글 달기
귀하의 답변을 추가하세요
Charles Drexler 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 851
