주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
iMac wont boot up
iMac 27" Mid 2011 2.7ghz intel i5
EMC 2429 A1312
Hi,
I was on my computer and all of a sudden it shut off. I tried to unplug it plug it back in and waited for a bit, and I still get nothing, it won't boot up whatsoever.
My guess is that the power supply is dead.
I was just wondering what the part number might be.
ALSO, Will a 2009 iMac PSU 614-0476, work with my 2011 iMac?
this is the power supply I found on ebay that I'm thinking of getting
http://www.ebay.ca/itm/Apple-iMac-A1312-...
Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
Have you checked behind the back cover of the PC? Dust could be an option or a battery.
What diagnostic LEDs are you seeing?
Also: Won't power up and only 1 diagnostic LED
ok so, i unplugged it for a bit plugged it back in, it started, then it randomly shut off i tried turning back on it it wouldnt start. so i opened it up and cleaned out the dust, it turned on and it worked again for a couple of hours and then it shut off again. the computer shuts off and you can see everything go to the middle off the screen and then disappear, it wouldnt turn back on. it looks like the power supply might be faulty. whenever you plug it in the wall while its off and listen carefully you can hear a small buzzing noise coming from the PSU
Wondering how this turned out for you, Matt M? Did you keep trying to fix it or is it time for the scrap heap? I find myself in a similar situation. I have not opened mine up, but it has not turned on and won't turn on. I bought a new power cord to see if that was the problem, and it is not.
댓글 달기
답변 2개
가장 유용한 답변
Try to disconnect the power cord from the iMac and the wall and hold the power button for 20 seconds to drain any power on the board then plug the power cord back to the iMac and the wall and turn it on. If it doesn't power on. Post your serial number to find it here is the instructions https://support.apple.com/en-us/HT201864 .
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I hope this helps with your iMac.
https://youtu.be/xYmtoaT9ImI
Best wishes!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
This is not a power button issue.
댓글 달기
답변을 추가하세요
Mat 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 6
전체 시간: 1,062
