주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether self-propelled or “walk-behind.”
Lawnmower problem with Fuel pump
I have a lawnmower that gets veey little gas coming out of fuel line. I have replaced fuel filter,pump, and lines. Now I discover the line coming from crank case is blowing air instead of a vacuum voming through line. What could be causing this and how could I fix it
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Check line from valve cover for cracks and leaks. Set valve lash. Plus check compression on that side cylinder. Mine developed rust scarring on one side, blew smoke. Am re-ringing with oversize and bore. One thing that helped for a little while was running a gravity feed fuel cell on top of hood.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tony Coleman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 235
