The AUX doesn't work, the Jack Socket was broken
I have a Bose bluetooth speaker II, the hole of AUX was broken, how can I fix it.
Thank you very much!
좋은 질문 입니까?
좋은 질문 입니까?
@chunxia this sounds like the AUX has come off and been pushed in. this guidewill get you to the boards. then take a couple of good pictures and post those with your question. It will allow us to see what you see. Use this guide 기존 질문에 이미지 추가하기 for that. Most likely soldering a new connector to it should resolve the problem.
안내서
난이도:
아주 쉬움
2 - 5 minutes
안내서
난이도:
어려움
6 minutes
해당 답변은 도움이 되었습니까?
Hi, I have the same problem: is the AUX port definitely soldered on, or is there a way to fix this issue without soldering? Thanks, Lucas
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 979
