주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
How to upgrade to El Capitan MacOS 10.11.x
So I need some help guys :(
I've bought an iMac 20” 2.4GHz Core 2 Duo (Mid 2007). But, it only came with OS-X 10.6.8, I want to upgrade it to El Capitan Mac OS 10.11.x
I want to know how do I go about that can you guys can help me.
thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
댓글 달기
답변 2개
선택된 답변
You'll need to upgrade your system to at least 2 GB of RAM (best to go all out to the max 6 GB of RAM).
As far as getting the OS you'll need to find a friend with a Mac that had at one point downloaded it. Apple has removed from the App store availability of the older OS to push people to the newer OS's. While once you've installed it on your system from the Apps Store you can access to it again, its hard to get it afresh like what you're doing here!
OK, you found a friend who at one point had El Capitan. Have him go the the 'Purchased' tab on his App Store account. He should then be able to download it again for you (he may still have it in his Application folder). Once it downloads it will ask you to run it, you want to quit the installer. You'll find the Installer in the Apps folder, copy it and paste it onto the desktop.
Now you'll need to prep up a 16 GB USB thumb drive (GUID) following these steps How to make a bootable OS X 10.11 El Capitan installer drive.
Once done you'll use it to first test your systems drive using Disk Utility, then run the installer. Done!
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
okay so am about to go to my brother house cause he have a mac with that ... could you add ne on instgram to walk me thru it my insta gram is @savetheyouths
Sorry I don't have instagram
My iMac is running 10.11.6 at 5gb ram.
댓글 달기
Hello There, well.. all you need is to have an Apple ID account, and use the App Store App included in 10.6.8..
when you successful to have your account, go search OS X Capitan, and you can download it (it takes some time because its like a 4gb download), and when finish downloading... you'll be able to install it...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
thank you . But when i look up OX X Capitan in the qpp store it only show like book guides
댓글 달기
귀하의 답변을 추가하세요
Adain 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 4,972
